Hi All,
I had a Pentair 5G color light installed about 2.5 years ago. It stopped working a month ago. I ordered a Sunseeker light engine replacement. Today I went to install it with no luck. I tested to see if there was power coming into the light with a non contact voltage tester (tested the cable). It appears there is power to the fixture, but when I test the voltage after the transformer inside the fixture, there is no power. Is it possible that the transformer is the defective culprit?
