Pentair 12 AMP Intellichlor breaker tripping (Revisited Thread)
jtapoolowner
2
Arroyo Grande, CA 93420
Pentair Intellichlor IC-40
Hello all,
New to this forum and trying to diagnose an issue with my pentair IC40 salt water chlorinator. There was a lot of information from a thread about 2 years ago with great information from @Dirk and @Jimrahbe. Hoping one of them, or someone else can chime in to help.
Here's my scenario...Noticed a little algae developing in pool and checked chemicals. No chlorine! Then checked pentair app to see about increasing salt chlorinator output. App showed salt level 3500 and Intellichlor output 25%. Now I go to physical salt cell and notice no lights.
***So Dang Frustrating that the Pentair app had no indication/warning that the salt cell wasn't even powered on. ugh!!! That's another problem for a later time.***
I go to Intellicenter control panel and notice 12amp low voltage breaker tripped. Re-engage breaker and immediately trips again. Go to Google to find possible fix. Directed to troublefreepool and find thread from 2022 describing same issue.
No obvious burn marks on circuit boards. Next, I watched the youtube video on that thread and did a volt test and found it is wired correctly for 120V. Next, 120V confirmed to the filter pump load. I do a load test on circuit board which results in 26V. In the video it says the transformer should have somewhere from 30-35V coming from the transformer for the salt cell.
So 1) Should the transformer have 30-35V on a 120V load compared to a 240V load in the video? (Im not an electrician so hopefully that doesn't come off as a silly question).
2) If 120V should still have 30-35V load from the transformer my guess is to continue following video and replace the circuit board?
3) However, If 26V is within acceptable range for 120V load, then what are my next steps? Does this mean my transformer is bad and maybe the circuit board too?
Side note is that all equipment is likely out of warranty I'm assuming. Installed just about 5 years ago.
Thanks in advance for everyone's expertise!!
Jeramy
(Arroyo Grande, Ca)
Jeramy,
Transformers rarely ever go bad...
Unplug the cell and see if the breaker pops.. If it does, the surge card is bad..
If it does not pop with the cell disconnected, and does pop with the cell connected, then you can kiss your cell good by...
Sorry for you loss,
Jeramy,
Sorry for you loss,
Oh Dang, ugh. Yeah, it seems to be just fine when I reset the breaker. The green light on the circuit board stays on, etc. The second I plug in the salt cell it trips. Anyone have $1250 laying around they wanna venmo? haha!
AG! Was just up in Pismo... miss the central coast....
Had the same issue happen yesterday... except on my test the results are were when i unplugged the cell, turned on IC60 circuit the 12v breaker popped.. guess I have a bad surge card.. wonder if it is under warranty being just over a year old or so..
