I am writing this as a record of my steps in dealing with a situation I'm sure many of my neighbors in Texas are dealing with.
In central Texas, the pecan trees are occasionally infested with aphids in late summer. The aphids will suck sap from the underside of the leaves. The sap is under so much pressure from the leaf that most of it passes straight through its digestive system and is excreted in the form of a sweet sticky honeydew. Every surface in Austin near a pecan tree is sticky right now, with a thick layer of honeydew raining down from the trees, including my pool.
As a result of this honeydew rain, our pool has been cloudy for the past few weeks. I was able to keep up by SLAMing it a few times a week (way more than usual), but then we took a trip for a week. During that time, the chlorine level was not maintained well and dropped to zero for several days. We came back to a green cloudy swamp.
I restarted the SLAM process and realized something was way off. The pool was consuming chlorine in under an hour. So I did a full suite of tests to discover that the CYA level had dropped from 35 to 5.
I've been following the steps in this article, assuming that bacteria have consumed the CYA and converted it to ammonia.
www.troublefreepool.com
I slammed the pool 10x until the OCLT finally held for the past 2 nights.
I am 5 days into this process, having cleaned the cartridges halfway through.
The water is still cloudy, but I can see the deep end, and the green algae were gone after the 1st day.
As we are approaching October with cooler weather, how concerned should I be with bringing up the CYA level?
Can I slowly bring it up with dichlor over the winter as my main chlorinator vs liquid chlorine?
Also, after a situation like this one is similar to someone dumping 5 gallons of syrup in your pool. What is a reasonable timeframe for the water to clear up?
I will continue to document my results until the leaves fall off.
FC 10
CC <1
pH 7.0
TA 120
CH 600
CYA 5.0 (got this from the pool store)
Ammonia - Further Reading
FC 10
CC <1
pH 7.0
TA 120
CH 600
