Hello TFP members,
I just purchased a home with a pool and am a beginning in the pool game. I've noticed some bleach/blotchiness on a Pebblesheen pool surface. I was wondering if it was just calcium build up or if the surface was potentially bleached? I read about vitamin C and chlorine puck tests to see organic/non-organic. Hopefully can do that when weather gets a bit warmer. From what I can tell, the blotchiness looks likes in on the bottom and sides of pool, in addition to the spa.
Any input would be appreciated! Hopefully my signature will work and has all my pool details.
I tested my water with a Taylor test kit and readings were below if it helps troubleshoot:
PH: 7.8 ( 1 drop of reagent to get down to 7.4)
TA: 110 ppm
FC: 2.0ppm
CC: 0
CH: 175ppm
CYA: 35ppm
16k gallon pool, Pentair DE filter, 1 Pentair WF-28 main pump, 1 Pentair WF-24 waterfall pump, 1 Polaris side cleaner pump, Pebblesheen surface, Pentair heater, air blower, SWG (but currently broken/not in use)
TA: 110 ppm
FC: 2.0ppm
CC: 0
CH: 175ppm
CYA: 35ppm
