A few years ago we had someone replace our pool coping.
Our Pebble Tec goes all the way up to the coping. When he replaced the coping he did put in some pebbles with grout. It does not match what so ever for the first 3-4" on the pool wall.
The base is pebble tec but the surface of the first 4" is not, as you will see in the first picture.
I just redid the entire coping myself (flagstone) as all of the stone was loose. During this work some of the pebble tec chipped off in large sections
I thought maybe now is a good time to remove the first 4" of non pebble tec. (It's so annoying to be the guy that always has to do everything right, and fix everyone else mistakes
It is very hard to remove.
I used a diamond tipped blade for the angle grinder and then chipped out the entire pebble tec down to the mortar. This is a lot of work and also has potential to remove too much.
My understanding is I only need to remove 1/4" and then patch it using the product "Pool Patch"
What is the best way / best tool / process to remove the surface of the non pebble-tec pebbles?
Any tips you have is greatly appreciated!
