We had the pavers around our pool stripped and sealed. It has been a week and the pool still has a green cast. We’ve added gallons of chlorine so it’s not algae. The water is clear just greenish! Can anyone help?
Was the water greenish when it was filled? Is this a new pool and fill? Did it go green after the pavers were stripped and sealed as if that might have something to do with it??
Tell us all the chemicals you've added to the pool?
Do you test your own water with a GOOD home test kit....if so which one? NOT pool store results as they're usually wrong.
We need chemistry results for:
FC
CC
pH
TA
CH
CYA
The two kits we trust to test water are: K-2006C from Amazon, or the TF-Pro from www.tftestkits.net
Yes the testers cost a bit of green, but they truly are an investment in your pools water health and equipment lifespan.
