Hallelujah... THANK YOU ... THANK YOU ... THANK YOU ... AFTER 2.5 yrs of struggle and algae I have been reading and utilizing the advice from TFP.com for less than 5 weeks (and thats ONLY because of life getting in the way) and my pool is crystal clear and I actually SWAM in it today!!!
So I checked the FC last night 20ppm and just before sun up I checked again... 20ppm
My current numbers at 12 noon were:
pH 7.4/5 - adding 8 oz of muriatic acid
CH 200ppm - adding 40 oz CaCl
CYA 30 - adding 8 oz CYA (stabilizer)
FC 15
TA 120ppm
Now...
How much per day do I let the pump/filter run?
When do I let the pump run?
When the PoolMath says something like 40 oz. like CaCl by volume can I use (5) 8 oz cups?
Lots of questions... but for now Im gonna go add some chemicals and then a little later for a quick dip.
FC 15
TA 120ppm
Now...
