- May 17, 2013
- 7
I've done extensive google and forum searching, but can't find a specific answer. My Paramount 6 port water valve has required frequent oring replacement. It seems every time I open the lid, I have to replace to oring. That means at least once a year. Had a tech by to replace a pump motor (warranty), and he placed a new oring on it yesterday. Checking the pool today, the in ground pop ups have not been working. What can I say, my paramount valve is a little old and needs some persuasion to work properly. So I opened up the paramount canister, turned the gear slightly, and attempted to close the canister. My oring is stretched again. Can't get a good seal, because the oring will no longer fit in the groove. I'm going to buy another oring today, and also some new pressure gauges, as the gauge on my paramount and on my multiport are not functioning anymore. I guess the pressure could be too high. Anyone else have similar experiences? Anything I should try?
