Our in-ground has a Paramount Paralevel autofill that has been an equipment bane since initial installation.
We have a "smart" water meter that sends alerts when gal/hr water flow exceeds a preset amount. 99% of the time, when we get these alerts, it is related to our auto-fill system and shutting it off at the main valve generates a "Leak Stopped" message within the hour.
The issue typically arises after we have an extended period of heavy rain and the autofill will stick and run continuously. I've wet-vac'd any debris out, and have replaced o-rings in the past and that seemed to help, Lately though, it hasn't seemed to make any difference.
Of course, I've considered that it's running due to evaporative loss, but we previously had it set to keep the level right below the overflow and didn't get any leak alerts for several months. Now, we are overflowing water at the same level setting. If I run the float all the way down below the pool, it still runs. I've checked the integrity of the float and there doesn't appear to be any cracks or water holding within.
Curious if any Paralevel owners have experienced the same and what, if anything, remedied the issue.
