- Mar 31, 2022
- 77
- Fiberglass
- Pentair Intellichlor IC-20
Hi All:
I have 4 PAL Lighting Treo 2T4 lights in our pool. Today I found the outer ring of one of the lenses in my robotic vacuum filter. Then center of the lens seems to be intact and still attached to the fixture. The outer ring is cracked and needs a replacement. For now I took the cracked ring and just snapped if back on the fixture until the replacement arrives.
Can anyone out there that has experience with these lights verify that this ring just snaps back into place or am I missing something. Also since the center lens is still in tact can I assume that the water tight seal is still in tact and it is safe to use the pool?
