- Mar 31, 2022
- 66
- Fiberglass
- Pentair Intellichlor IC-20
Well, After 2 1/2 seasons our PAL lights have some big issues. We have four PAL Treo 4 wire 12 volt lights (Model #: 2T4). The are connected to two PAL 12 volt Driver / Receivers (2 lights on each) (Model #: PCR-2D-35). The drivers are connected to automation and we do not use the wireless remotes that came with the drivers. Instead, we use the Intellicenter app. All 4 lights are getting dim, and as of yesterday one of the drivers died. I took a multimeter to the power wires on the dead driver and was getting 118 volts, so it is getting power. Inside the dead driver there is a power LED which is not illuminated, so I am confident it's a dead driver. The research I have done shows the 2T4 lights are nicheless. I am thinking of slowly starting to replace this equipment. Seems like the 2T4 lights are discontinued, and the PAL Treo Max lights are the current replacement. The Treo Max lights are duel rated for 12 or 24 volt DC. The PAL 12 volt Driver / Receivers are currently hard to come by so when I replace them I will go 24 volts. Here are my questions.
1 - The lights seem to be replaceable with both the 2T4 and the Treo Max (without replacing the plug or cable). Both are 4 wire lights. Do you think I could just unplug the old 2T4's and plug in the new Treo Max on the same wire (thus not having to pull a new wire). (See link to brochure https://pallighting.com/brochure-files/PALTreoMax.pdf )
2 - Does the water in the pool need to be drained below the lights to do the replacement of nicheless lights? (I have a fiberglass pool and I am not crazy about that idea.)
3 - I noticed with Pool LED lights some are 2 wire and some are 4, how do they differ?
Thanks everyone.
Thanks everyone.
