My teeth are fine, but I had to take a few days off to let my back recover. Should be back at it on Monday.
That’s just weird. They really use bad clamps on the pipes underground?4-24-2023 - My plumbing plans changed this morning when I discovered that I accidentally punched a hole in one of the return lines during my jack-hammering marathon.In hindsight, I spent too much time with the big boy hammer. That thing got really heavy by the end of the day. I should have switched to the little guy much sooner. Who said "I won't have to dig any further than this" ?!?
After 2 hours of digging with the small hammer, I uncovered enough of the return line to allow me to cut it off and attach an extension. The good news is that the line coming out of the pool is actually grey PVC, not black poly, so attaching an extension should be a lot easier and more reliable than if it were black poly. You can see in the photo on the right where the Grey PVC is glued so a coupling, which is then glued to a barbed socket fitting, which is turn clamped to the black poly.
View attachment 488708View attachment 488711
Uncovering the other skimmer lines revealed essentially the same thing. Not sure why they used grey PVC for the returns and white for the skimmers, but it's good news for me. What you can't see in the photo below is that the black poly pipes attached to the 45deg PVC elbows only extend for about 3-4 feet out of the hole before they make another transition to the flexible PVC lines next to the deck. Once I discovered this, I decided to change my plans and abandon the black poly pipes altogether in favor of PVC for everything. Now that my exploratory excavation is complete, it's time to go order some plumbing parts...
