- Nov 12, 2017
- 12,663
- Plaster
- Pentair Intellichlor IC-40
I'm advising a fellow TFPer as he replumbs his pad. Very simple setup: pump -> filter -> SWG. We are working on how to best physically locate the various components, as he can do so any which way works best. I convinced him to ditch five old PVC ball valves (three suction, two return) and replace them with three quality three-way valves. I'm pretty sure I have the schematic right, but my question is:
Can a Jandy three-way valve be configured any which way? If he needs two "inputs" and one "output," can any of the three ports be used as the output? That it's just a matter of disassembling the valve and reconfiguring the gate?
In order to facilitate the layout, he may need to have one of the two side ports be the output, while the other side port and the middle port are the inputs. I told him this was doable, but I've never actually done this myself, so I'm double-checking.
R = return
M = main drain
S = skimmer (there are two)
V = three-way valve
R = return
M = main drain
V = three-way valve
