- Nov 15, 2022
- 58
- Plaster
- Jandy Aquapure 1400
I'm going to be installing a saltwater system for my pool, and I figured as long as I'm going to be doing some plumbing work, I should see if there are some adjustments I could make to improve my setup. I feel like there may be some 90 degree joints I could eliminate, but not certain. I assume I want to keep all the equipment where it's at on the pad since that's how the builder originally laid it all out, but I suppose if there are opportunities to improve the layout I'm open to that.
I was planning to replace the plumbing mostly as-is unless there are recommended changes. I'll definitely be replacing the runs between the filter and heater and from the heater back out to the pool.
I also have 3 pipes stubbed out and capped off at the pad that I have absolutely no idea what they are for - is there any way for me to figure that out?
