Hello, I just had my 40 year old pool redone this past month. Had the pb install a new multiport valve over the old push pull valve. Now I’m not sure if it is the correct one. My de filter is a pac fab nautilus ns 60 stainless . The new valve is a pentair 261142. Is this the correct one? The reason I ask there is a label that says for triton and quad de filters only.
One of the problems I’m having right now is when the valve is on rinse mode there is no water going to the filter no pressure. When I try to move the leaver to a different mode pump off of course it will not move. I have to Remove three screws from the lid to release Pressure and blend the air valve on the filter to be able to move the lever to a different mode. Attached are photos of the equipment pad.
