I setup my Intex XTR 18' pool a few weeks ago - and am just getting started with the chemical maintencance process. I have the Auqa Check test strips and have got a chlorine tabet float in the water.
I tested last night, and the results were:
Total Hardness (Low, probably around 75ppm)
Total Chlorine - Around 3-4ppm
Free Chlorine -Around 3ppm
PH - Low - ~6.5
Total Alkalinity - Low, 20ppm
Cyanuric Acid - Low, almost zero
I purchased PH+ Sodium Carbonate and Stabilizer Cyanuric Acid.
Using the dosage charts for an 8500 gallon pool, it says to get from 0 to 50 ppm of Cyanuric Acid, I needed Dang near 65oz of stabilizer. That's over 2 bottles of this stuff (28oz per bottle) and a total of like $20 to get to that level. I added what I had (28oz) in a bucket but it didn't dissolve well at all. I kept dumping the water (keeping the granules in the bucket) over and over, but it still hasn't dissolved and I don't want a bunch of white granules on the bottom of my pool. If i'm having trouble with that small amount, how am I supposed to put another 37oz of this stuff in there? Did I do that wrong?
I used this chart for dosage: Pool Chemical Dosage Charts - The Ultimate in Pool Care
Also - I'm not sure what to do about the PH and Alkalinity - Everywhere I read says add Sodium Bicarbonate, our store only has sodium carbonate. I looked at the dosage chart for that, and it says i'll need something like 11 pounds! What?!?! The tub I have is only 4.5lbs. That seems like a lot of chemicals.
This doesn't seem sustainable.
PH - Low - ~6.5
