So my TA is a bit high, 110 and my pH was a little high as well at 8.0.
So I wanted to lower the pH with muriatic acid and then raise the pH up to clear out a bit of the TA. Was hoping my pH would then hover around 7.6-7.8 instead of 7.8-8.0
So I put my muriatic acid in (I only had about 48oz left, so i used that) and knowing very well that you can't put chlorine in, I waited a good 2 hours with the pump running around 2850rpm and cycling the water.
So I put my gallon of chlorine in after the 2 hrs.
I know I Am probably being paranoid, but that is completely safe to do right? Waiting 2 hours and putting in chlorine after muriatic acid of 48oz? How close and how much does one have to combine in order to create deadly toxic gas from the combination of the two?
#s for the sake of it:
FC 2.0 (prior to adding chlorine)
CC: 0.0
CYA: 40
TA: 110
Hardness: 150
Am I being paranoid or am i on the fringe of concern?
CC: 0.0
CYA: 40
TA: 110
Hardness: 150
