Overheating
mplsdon
2
Indio
I have a Pentair MasterTemp 250 heater for my spa. Last night I set the temp to 95 and waited a couple hours before going in. When I went in, the spa seemed quite hot. I got a thermometer and found that the water was 105 degrees. I went back to the heater and the readout said 95 and the heater was still going. Any ideas? Thermistor? Circuit board? Thanks
Most likely the thermistor on the heater manifold.
You can test the thermistor using a multimeter and measure the ohms which indicate the temperature it is reporting.
