Good evening all. I have a concern about my pools overflow setup. This is a new construction home we have been here since December 2022. We had our first hard rain this past Sunday and Monday. Monday evening I got home from work and my pool was about 1" from overflowing itself. I wanted to know y'all's thoughts on how the overflow is installed and if maybe it should be lowered. I'd also like to know how it works. I don't have any grade to my lot and my pool is not elevated so it's tough for me to believe it's working as it should. I have a pipe behind the pool paver deck that looks like two 90's put together but I don't know where it goes. In the pool, on the wall I have a port with maybe a 1" hole and a snap-in grate over it that I believe is hooked into that pipe in the grass. I had to pull the drain plug out of my filter housing and run the pump for a minute or two and let it flow out into the side yard, which alone was sketchy because it almost comes back into the pool. I'm open to any suggestions, advice or information.
Also the other hole in my skimmer floor is not hooked to anything because I've been told that's usually an overflow.
