"When I explain that the blocks under the track have no structural value, some homeowners look at me sideways and don’t believe or agree with me on this. If you work in computer science or are an engineer of some kind, chances are you won’t agree with me as these two professions must attract the overly intellectually arrogant. In this case, it doesn’t matter if you are wrong, as it won’t hurt anything to overbuild. You can spend your whole week digging and leveling giant unnecessary pieces of concrete materials. I’m sure your body needs the exertion and your soul will enjoy being outside for a change. Certainly there is value in everything we do."
Leveling an Above Ground Pool
www.inyopools.com
I gotta agree with Dan Dougher on this one. There is absolutely no benefit to using 4" thick blocks over 2". The blocks do not serve any special structural function, the wall MUST rest evenly supported around it's entire perimiter, if the blocks were somehow providing some special greater structural support than the ground in between them what you'd get is a crumpled wall and in fact this is a common problem, look at any DIY AGP and you will likely see slight buckling around at least one of the blocks because the ground around it settled. They are only a helpful guide for alignment and leveling of the track, as well a keeping the bottom caps neat and level.
