Consider a basic Jandy Nevetlube 2-way valve like this one.
Is there a correct orientation of the valve as far as which side the sealing part of the valve should be when the valve is closed? As I see it, it would be better to have the sealing take place on the down stream side, so that the pressure pushes the seal against the seating surface. But this means the valve body is itself under pressure which perhaps is not desirable.
If it's not clear what I'm asking let me know and I'll sketch something. Thanks!
