We finally ordered our new AGP - a 21'x54" all-resin pool. I want to put out the gist of my installation plan and see if anyone notices any issues or has any suggestions. I am in Canada by the way.
First, what we ordered (everything from Pool Supplies Canada):
For the install:
For the equipment:
For my maintenance disconnect, I think the Hayward panel breakers should meet code for this - is that true?
For bonding of pool, all resin except for continuous steel wall. I was going to bond the pool wall seem, all equipment, and use a Permacast water bonding plug in a T near the filter - this sound OK?
To drain pool for winter, I was going to install a Jandy 3-way valve on pump plumbing pipe, between pool and pump. Do I need a 3-way here or can you drain at the sand filter (without having to filter the water you are draining)? I would be relying on gravity to drain to skimmer, then bucket a bit more out, I suppose?
Would also add a 3-way valve after filter on return line, for future solar expansion, though I may really just need a 2-way here?
Thanks to anyone who read all the way through this and has any advice, criticism, or otherwise!
- 1 1/2" HP, 2 speed Hayward Turbo Flo Matrix pump
- 21" Hayward Pro Series Sand Filter
- 200lb Equivalent Filter Media Balls
- Cove, wall foam, and Gorilla pad
- Carvin StarBright White LED Return Jet Light
- Hayward ProLogic 4 Relay PL-P4 Panel
- Hayward T-CELL-15 Salt Cell
- Hayward P-KIT Flow Switch
- Jandy 3-way Never Lube Valves x2
For the install:
1. Level pad and install concrete pads for feet
2. Put up pool
3. Put down 1" XPS foam board on ground inside pool.
4. Install coving and wall foam
5. Put down Gorilla pad over XPS
6. Install liner and the rest
For the equipment:
- Install pool equipment "pad" 8' from pool wall.
- Install Hayward ProLogic with 50 amp service.
- GFCI breaker to feed twist-lock plug for pump
- Non-GFCI breaker to feed GFCI convenience outlet.
- LED return light will plug into above GFCI outlet.
