I have an in ground gunite pool/spa. I have a Polaris cleaner that I leave in the pool and it works great. The spa is another story- I have to manually vacuum it and drag out the hose, pole, close drain valves etc, just to clean a 9x6 spa. I have tried putting my Polaris in there, but the space is so small it just traces over the same spots and doesn't get corners or the bench seating. In the spa there are a lot of tight corners vs the rounded sweeping corners of the pool. I looked into a "pool blaster" vacuum but the online reviews said it was garbage.
Would a Dolphin take care of this better than the Polaris? . The Polaris came with my pool install so my plan is to use it until either it or the booster pump breaks down, then replace it with a Dolphin. Just wondering in the meantime if there is an easier way to keep the debris off the floor of my hot tub.
