Opening early and hopefully getting this conversion done by May. Going through Leslies for liquid chlorine and picking up the Taylor K 2005 kit as well. I will keep you all updated with pics and questions I’m sure.
It doesn’t look like they have it. Any major differences between the 2005 and FAS-DPD(81329).It’s the K-2006 test kit that you want, not the K-2005
Good luck with your conversion though![]()
Never mind. The fas dpd is the 2006It doesn’t look like they have it. Any major differences between the 2005 and FAS-DPD(81329).
Major advantages of the k2006?
Thank you for the info.Hunter, if you order the FAS-DPD your 2005 kit essentially becomes a 2006. Welcome to the forum.![]()
“They” is Leslie’s. Only pool store around here with quality LC at the time. Not sure how long the pool has been on baquacil but I’ve used it the last 2 seasons and unfortunately with the CDX.If I may ask, where is “they” that you’re looking at?
you’re going to use a ton of reagents so prepare to need a refill somewhat quick with the Taylor kits. How long have you used Baqua in the past?
If they have 187 bottles of old stock, might see if you can make a deal and pay 50 cents or a dollar bottle. Of course, they may have no idea that it degrades over time.LC was almost 10 months old
