Here is the situation. my pool is closed and has L shaped PVC to keep jets above water level. I am getting a new cover and have to raise the water up to the skimmer.
Would it be an issue to fill the pool before officially opening it? (IE starting anything/removing those l shaped pvc/etc...) They need the pool level raised before they can install the cover. I just do not want to open the cover to remove everything because once I do I cannot close the cover without the new cover.
Thanks
Thanks
