Opening pool with "dead" water
Last night measured FC: 13
This morning after running the pump all night....13.
That's weird, right? I'll check it after the sun comes out for a few hours later.
In other news the pool is super clear now and I can see the bottom clearly. It can't be this easy...can it?
By George, I think you've got it!
Now stick around and answer some green pool threads. Right here is the proof you know what to do now
It gets even better! Woke up this morning to a crystal clear pool. Passed the OCLT and now the FC levels are drifting down to normal levels. Went through and vacuumed the bottom thoroughly to get all that junk out and tomorrow the FC level should be within range for swimming if it continues to drift down as it has been.
Thank you all for the help!
