I have a plaster pool 30,000 gallon. We opened it this morning and removed large debris (mostly leaves). Pump/filter is running and slowly raising water back to half skimmer level as it was a little low from closing. Pump is pulling from main drain currently and then will switch to skimmer once level is up. So, here are my water results from Taylor kit:
CYA - not registering, so very low (my kits low end is 30 and it isn’t reading at that)
Calcium - 225
Alkalinity - 215 (seems to always run high and not sure if this is a problem)
PH - 7.8
Chlorine - 0
Can someone walk me through the steps to of adding chemicals from here? Should I let the pool run 24 hours before adding any chemicals? And should I completely vacuum it first?
A main question is if I need to shock (SLAM)? It is somewhat cloudy but not terrible. I just can’t see the deep end bottom.
Calcium - 225
PH - 7.8
Chlorine - 0
