Hi
Just a little confused about the order of things when pool is filled with algae. ( last 2 years I opened the pool was clear. Don't know what happened this past winter) So I know how to deal with the algae from reading through this site. (SLAM) But wasn't sure if I start with the SLAM or try to adjust my other stuff and then SLAM. I took a water sample yesterday and got CC 0, PH 7.5, TA 30, CYA 25, CH 100. I'm sure the numbers will change once I have the pump running for awhile. From reading through this site I read to lower PH to around 7.2 before SLAM. Also that with such low TA won't my PH jump around. Basically my question is in what order do I fix things at opening when I have a pretty bad algae problem? Also I have a DE filter, will the algae screw up my filter since I have to add DE powder to it when I start it.
this is what I was planning.
1. Scoop out as much solids as I could.
2. Start pump, add DE. Let run for a few hours.
3. Brush walls
4. Backwash as needed.
5. Retest water.
6. Adjust TA
7. Adjust PH
8. SLAM until clear
3. Brush walls
5. Retest water.
6. Adjust TA
7. Adjust PH
8. SLAM until clear
