@montek I am glad you are back with an update! You had me worried that we ran you off lol
Keep using your test kit
and trust your own results !
You can definitely do this!
You must keep fc above minimum for your cya at all times or nasties will grow.
Always follow the
FC/CYA Levels
There is no need to “shock” the pool separately as long as you do this. You cannot make up for a lack of fc on friday by raising to shock level once on Sunday.
You can use liquid chlorine or cal hypo to accomplish this task daily. But as you know cal hypo adds calcium along with fc. Too much calcium can cause scale to form. Large additions of cal hypo can also cause cloudiness. Thus the recommendation to use liquid chlorine for daily chlorination.
It sounds as if you’re on the right track but just a little light handed on your daily chlorine additions so lets bump that up a bit.
If we’re calling your cya 100 then here’s where your fc should be every day.
