YesPlease tell me those tests are after you added all that stuff.
I added 5 gallons at 7 amIt takes nearly 4 gallons of 10% to get 10 ppm FC into your pool. You have a very large pool. Remember the M in SLAM is for Maintain.
2 gallons at 11 am
3 gallons at 2 pm school math
Added another 4.5 gallons per pool school math to bring it back up at 5pm.
Forgot about the last 4.5 gallons in my previous post! So I’ve put in almost 15 gallons today!!
Am I supposed to be adding chlorine after dark to bring levels back up to slam and test again at night for the OCLT?It takes nearly 4 gallons of 10% to get 10 ppm FC into your pool. You have a very large pool. Remember the M in SLAM is for Maintain.
Yes.Am I supposed to be adding chlorine after dark to bring levels back up to slam and test again at night for the OCLT?
I clean my DE filter daily whether it needs it or not.Don't bother with OCLT tonight because you need the extra day of slam to be 100% sure so then tomorrow night do the OCLT along with all 3 criteria to call it done. I would recommend you backwash the DE filter tonight as there plenty of dead algae regardless if there's psi rise or not.
This would be highly unusual. Cleaning your DE filter involves backwashing and re-adding DE. Perhaps you are thinking your skimmer?I clean my DE filter daily whether it needs it or not.
No I’m talking about my filter! I pull cartridges out daily, clean them, then clean the filter body, put all back together and add DE media through my skimmer! I do this every evening.This would be highly unusual. Cleaning your DE filter involves backwashing and re-adding DE. Perhaps you are thinking your skimmer?
I can’t backwash my filter or I just don’t know how. So it’s a complete pull apart and put back together every evening.This would be highly unusual. Cleaning your DE filter involves backwashing and re-adding DE. Perhaps you are thinking your skimmer?
The manual says to add DE to it! It came with the house.Hayward C2030 is a cartridge filter. Not DE. It is a tiny filter for your size pool, but you should not adding DE to it. If it is the filter model you state in your signature.
