This will be my third season managing my own pool, and I've done pretty well so far. Only had one algae issue when I left a family member in charge and they disregarded my instructions
Anyway - we had new plaster put in at the beginning of last season. No issues, the pH tended to drift up but I understand that to be normal and I managed it accordingly.
I opened the pool early so I can monitor any issues easily, pool is now clean and clear, just needs to be balanced. I have a good understanding of how to address each number below normally, but I wasn't sure if there was anything special to keep in mind in light of the somewhat new plaster (about 10 months old at this point).
Basically, just want to know if I should do anything different than usual.
This morning's results:
FC 0
CC 0
pH 8.2
TA 40
CH 150
CYA 30 - this test throws me, the dot was clearly visible still at 30, but it's the lowest the test allows.
Temp - 60*
Plan:
FC is already addressed for the moment with liquid chlorine.
As far as the pH/TA - should I just address both per TFP app recommendations? I addressed the pH last year with muriatic acid (carefully). This is the first time I've had to actually touch the TA, but baking soda is easy enough.
CH - again, address as normal with Calcium Chloride?
I have Chlorox Chlorine Stabilizer (100% CYA), so will add via sock per TFP app (~2 lbs)
FC 0
CC 0
pH 8.2
TA 40
CH 150
Temp - 60*
Plan:
