Hello,
I began opening my pool for the first time after a 3 year hibernation. We purchased a home this spring including an 18' x 36' vinyl liner pool (~26,700 gallons), which has been closed for the past two winters. So, I removed the cover this past weekend; unplugged both skimmers and inlets, removed the Gizzmos from the skimmers, replaced the drain plugs in the pump, filter basket and chlorinator. I began with some surface and deep skimming to remove solids.
I did some experimenting with the filter to begin understanding how the multi-valve worked along with troubleshooting various aspects of the DE filter. After doing a tear down of the DE filter (Pentair FNS Plus 60) I learned I needed to replace the manifold (original was cracked) and install a bulkhead O-Ring (no O-Ring in place when disassembled). I had purchased filter grid replacements by Unicel since the pool inspector was the same one who winterized it almost 3 years ago. He indicated some of the filter grids needed replacing. So, reassembled the filter with the cracked manifold, missing O-Ring and put back a few of the less damaged grids. I fired up the filter and added the recommended amount of DE in order to just try out the filter. The pressure at startup was ~15psi and within an hour was at 27psi so I felt nervous and shut the whole thing down for now.
Waiting on my manifold and O-Ring. These arrive tomorrow and I plan to backwash and rinse the filter, install the new manifold, replace any other cracked filter grids, install the bulkhead O-Ring, and recharge with DE, then keep the pump and filter running for the SLAM.
I have the TF-100 test kit and am planning to begin a SLAM this Memorial Day Weekend. After watching several videos, here is my strategy. Please comment and criticize - feedback is welcome:
1. Get the Pump and Filter up and running - IN PROCESS
2. Test, Test and Retest the water as follows:
a. Test for pH (before adding any chlorine) - looking for 7.5 - 7.8 (add soda ash to increase pH as necessary and add muriatic acid to reduce pH as necessary)
b. Test for CYA - looking for 30 - 60 ppm for non-saltwater pool (see pool calculator to add or lower CYA)
c. Test for Free Chlorine
d. Determine Shock Level (see TFP for chart of CYA - FC recommendations)
3. Start SLAM once pH and CYA levels are known
Okay, I will have follow up questions if you give me feedback so thank you in advance! Also, here are a couple of "before" photos once the cover came off.
View attachment 61811View attachment 61812
