OK, so, this is typical for me, after winter, leaves that had been on top of the cover, with water draining thru, will leave my water typically on the black side. I have not yet started up the filter, but that will be in the next day or so. Can I filter this out, along with using shock? or do I have to drain and refill? I used to have an intex, but last year moved up to a doughboy. the salt start up process is understood, I am just wanting to clear up the water. we have a couple trees that like to drop leaves late in Nov after I close it up. I usually keep most leaves off it, but I still get enough to cause these issues every year. I dislike having to drain and start over, will do if needed, but prefer not to. roughly 7000 gal I think.
thanks
thanks
