The op lowered ph to 7.2 at the beginning of the
SLAM Process as recommended.
He hasn’t updated the thread in almost 3 weeks - hopefully his slam is over & he is now following recommended maintenance levels.
Funny you should mention my lack of an update, was just getting ready to give one today.. with that being said, here's the current situation:
So I followed the SLAM process pretty religiously for about a week and a half to two weeks, checking the chlorine levels at least three times a day, sometimes more, adding chlorine when needed. I'll admit I didn't get the chance to vacuum and brush every day like I'd have liked but that's not exactly relevant anymore I don't think. I think it's also worth mentioning that I checked CYA levels a few times throughout that time frame and adjusted SLAM FC level accordingly once or twice.
After that first week and a half or two weeks.. life got in the way. Between getting extremely busy at work and working long night after long night, and then being sick with COVID for a week, my SLAM process pretty well turned to nothing. It also didn't help that right before getting COVID I had pretty well depleted my liquid chlorine supply. That being said, by the time I got around to being able to actually tend to the pool again, the water level had dropped to a point where it needed water added before we could really run the pump without worrying about starving it for water. So my girlfriend and I had a decision to make.. We hadn't really seen ANY noticeable improvements visual or otherwise to the quality of the water since starting the SLAM process, and hadn't seen it get much worse after letting it sit without SLAMing once life got in the way. Considering the pool needed a good amount of water to be at a "proper" level again, and given how frustrated we were with everything, we decided that we were either going to drain the pool and refill with fresh water to start fresh, or close it and try again next year with a fresh fill. We decided that while we were deciding what to do we would shut the pump off, again to avoid damaging it or any of the other components.
Fast forward two days.. the pump has been off and the water has been sitting stagnant, I went outside, and could now see the bottom of the pool.. for the first time since starting this journey months ago. This was a HUGE spurt of inspiration for us as we hadn't seen the bottom of the pool since we moved into the house back in February, but I was confused as to why it was so clear given the state of the water could NOT possibly be great. The only thing that made sense was that since the pump wasn't circulating, all of the "junk" (mostly very fine algae I believe) had been allowed to settle to the bottom, making the majority of the water "clean". So now we had another decision to make.. what to do now. After doing some thinking and some looking, I decided to fill the water up and immediately vacuum the entire floor of the pool to waste. After doing that, the water had clouded up a bit just from stirring some of it up, but the bottom actually looked really nice and clean now. After vacuuming I went ahead and brushed the sides of the pool, and then added a gallon of chlorine, just to give it something, intending to come back today and vacuum again, which is exactly what I did. The bottom of the pool was much cleaner today than yesterday, but still had some spots where, as I expected, stuff had resettled, so I again went ahead and vacuumed the entire floor of the pool, to waste again, and refilled the water.
Now for my question.. Given this book of information I've provided, what's the next step? I went ahead and performed a full test again to get an idea of where the water stands chemically. Those results should be available through my PoolMath logs linked below. Do I now start working on properly balancing the water and leave the pump running until the water REALLY clears up, or do I continue with the SLAM process again? We're extremely excited as this is the clearest and the "bluest" the water has ever been but I know there's still some work to do to get it all the way there. Just not entirely sure how to proceed. Sorry for the delay in the update.. life's been pretty crazy.
PoolMath Logs: PoolMath Logs
Results Not on PoolMath:
CC = 0.5
TC = 1.5
CYA = Not exactly sure on the level of this, ran out of daylight so it was tested indoors, and could still see dot at 20 but it was close so I'm guessing near 15.
The first picture is of the bottom of the pool before ever being vacuumed, and the second picture is what it looks like now, after being vacuumed twice now.
