Hi All,
We opened our pool last week and it was nice and clear. Been adding chlorine (liquid chlorine) since opening.
Last night about 6 pm I added enough to get to FC of 7. Checked it tonight about 5:30 p.m. and it read FC 2 and CC of 1. Since the chlorine was too low and the CC was reading 1, I thought I would raise the FC to shock which is 16. Well, when I put the numbers in the calculator I forgot to change the percentage from 6% to 10% and added way too much chlorine. I added 553 ounces instead of the 340 I should have added. I got a reading of 29.5 FC. YIKES! So now only thing to do is let FC float down, right? Will this high chlorine hurt anything? It was 91 degrees today and should be the same tomorrow.
The reason I was going to raise it to shock level was because of the 5ppm use from last night to tonight and the CC reading of 1. No one has used the pool and I was thinking it was kind of high usage and didn't like the CC reading.
Was I going in the right direction before I added too much chlorine?
Pool is in full sun all day.
My numbers were:
CYA 40
FC 2 (now 29.5)
CC 1
TC 3
PH 7.5
TA 70
CH 75
Thank you for any advice or suggestions.
Sherry
My numbers were:
CYA 40
FC 2 (now 29.5)
CC 1
TC 3
PH 7.5
TA 70
CH 75
Sherry
