- Sep 15, 2018
- 955
- Plaster
- Hayward Aqua Rite Pro (T-15)
So, I added CYA (7-8 pounds) and that is now looking good (70). I also started running the pool 24/7 to heat it up. I also got a migraine (my excuse for what happened next).
I got all my shiny new reagents from TFTests, and did a full suite of tests. Chlorine through the roof! 22. (it's still only February , and I hadn't adjusted the swg down to account for the additional runtime.)
Quickly turned off the swg, so that number will drop fast. pH purple.. what? I had figured the CYA would have dropped it! No worries, add some MA. THIS is where I'm blaming the headache. Obviously the pH was reading high because of the high chlorine level.
This morning FC is 20, pH LOOKS like 7.2-7.4, which would make me super happy. IF I COULD TRUST THE TEST.
Kids are coming over. Should I add some baking soda blindly so the pool doesn't burn their skin?
Are the other acid/base tests accurate if FC is high? I can run those.
Pool is 88 and it's a beautiful day. How do we go swimming?
