Second day of slam, cya is 50, need to keep FC at 20. This evening pool tested FC16, needed to add 2qts 1cp of chlorine, by mistake I added 2qts of muriatic acid, started slam with ph of 7.3, can't test for ph because of the high FC. Typically ph around 7.3 which I do to balance the high calcium level of water. So....should I keep the slam going, will the low ph screw up the slam, should I add some borax not knowing what the ph is to try and raise the ph(according to poolmath it will need a boatload)? thanks in advance
