Chlorine will take care of all the algae. No need at this point to run other non-pool pumps as you could further damage the plaster.
Nothing as of yet. I'm stalking my mail box!Awww shucks... It's nice to get a pat on the back from the boss.
Probably so. News on the test kit?
hmm .. . add that to the "TO DO After I can see the bottom of my pool" list.
I can't get anything else off the bottom I've even gone so far as to use a ditch pump
I was in the same position of not being able to see the bottom and knowing I had a bunch of junk sitting on the bottom. You just need to keep using the leaf rake until you can see down there. Anything you rake out just saves you from having to use chemical. Raking saves you $$$ on bleach.
Here is some "show and tell" on that multiport valve. http://www.youtube.com/watch?v=hYGjjBZFF_s
