Situation
I've been reading threads on head on and off for a few years as I replaced parts of my system but I'm having a hard time putting it all together to figure out the best RPM to get the most heat out of my solar thermal panels.
Question
Is there an on-line calculator I can plug all my info into to get an RPM setting with/without solar?
Calculating head
I tried to calculate static head, but the tables I found top out at 2" and they requires the gpm which is what I'm trying to find so I can set my RPM.
On just the dips, turns and twists part I ended up with about 3200 feet of head which seems more than a bit off:
To Solar: approx 105' with 14 corners, 4 couplings, 6 45's, 1x 2-way ball valve (head: 10 + 14x 9.8 + 4x 2.5 + 6x 3.8 + .4 = 1459.6')
From Solar: approx 105' with 16 corners, 7 couplings, 3 45's, 1x 2-way ball valve, 1 Tee, 1 check valve (head: 10 + 16x 9.8 + 7x 2.5 + 3x 3.8 + 8.8 + .4 + 2.7 = 1674.4')
Rise: approx 25'
Sources
Calculate feet of head: How Do I Calculate Feet of Head for My Pool? - INYOPools.com
ELM Panel info: https://images.inyopools.com/cloud/documents/elm-install-manual.pdf
My Pool Info
Location Northern California (SF Bay Area Peninsula)
Pool 25k gallon in ground (about 600 sq ft surface)
IntelliFlo variable speed pump (installer set at 2800 RPM for solar, 2100 without)
400 sq ft solar (4x 4x10 polypropylene ELM panels with 2" header) on 2nd story
Solar Pipes
to solar: 105' w/ 14x 90°, 6x 45°, 4x couplings and 1x 2-way ball valve
from solar: 105' w/ 16x 90°, 3x 45°, 7x couplings, 1x 2-way ball valve, 1x Tee and 1x check valve
rise: about 25'
Pool Pipes
Don't know much because it's a pre-existing in-ground pool. Pump is only about 8' from pool edge though.
4x 90sq' cartridge filter (A/P Quantum 360) showing about 23 psi
No other heater
Bonus Question
The panels are rated for 4.0 max GPM but it looks like way more pressure is needed to run the system. Am I reading this the wrong way?
Thanks
Thanks for any help. I read the hydraulics 101 and the above sources. If there's somewhere else you could recommend I look that would be very helpful.
Question
Calculating head
Rise: approx 25'
Sources
My Pool Info
Solar Pipes
rise: about 25'
Pool Pipes
No other heater
Bonus Question
Thanks
