One piece Ceramic shell
UKjames
275
United Kingdom
I’m thinking of re doing my pool. One place uses an all in one shell made from carbon fibre and ceramic apparently. This is then craned in to place.
I wondered if anybody had any experience Of these?
Here they go under the brand of
“Compass pools”
Do you have a link that shows their process?
Reading the literature, it looks to be a fiberglass shell with a ceramic layer added for strength. And due to the rigidity of true ceramic, it's most likely a blend of ceramic with other materials. I don't see any issues with the shell as described.
Page 12 references ceramic micro-spheres. If that’s the only ceramic, then those are just a filler material in the resin to reduce weight and are sometimes used for insulating properties. Not sure how much insulation benefit they actually provide though. I suspect it’s more of a side benefit with the primary reason being used to fill out the resin.
