i have no 45's or 90's. all my plumbing was heated and swept for turns. the only time there is a break in my PVC is if the piece needed a coupler due to run length. i know a lot of builders seen here uses 45's but a lot also heat and bend. it just takes some skill. you can blow a line out pretty easy. i saw it done on my build when senior was teaching his grandson who will be one day running the show how to heat and bend and he blew a line out. i was there laboring most of that day to help with digging and there deff is some finesse to the process.
i think you will get answers both ways are ok. which is better. i would say less physical connections is better cause it's less failure points, but that is if the guy who was heating and bending knew what he was doing i would say.
to edit. . . i have bends coming up from the ground at the stack of equipment, but everywhere else sweep bends heated.
jim
jim
