I just upgraded to Hayward OmniPL from my old eCommand system. I notice that when I turn on the pump manually, after the initially priming time, it defaults to the minimum pump speed, which I think is like 15% or 20% or 680 rpm’s or so. I could not get the minimum pump speed setting off my old eCommand as it died before the replacement so I went with the default minimum speed in the Omni setup wizard. Just wondering what considerations or rules of thumb go into setting minimum pump speed? On a related note, does the Omni system always go with the minimum pump speed when started manually?
