I am very unclear what to choose for adding the Pentair Intellibrite 5G Color Lights to the OmniPL (I installed the upgrade kit from Aqua Logic).
Choices are: UCL, CL4.0, CL 2.5, Incandescent and Other (see attached)
Also, I have Solar on the Pool with a Hayward VSP. All works great, except I have the schedule set up to run at 90% for 4 hours with Solar ON, and then at 60% for a few hours, but see no way to turn off the solar as part of the schedule, at 60% with solar on, I think it struggles to push the water through the solar so it has lots of air bubbles in the pool returns. Should be a way to schedule heat to come on and off (note: pool is not to set temp). In the warm months, with aqua logic, if at temp and it went to low speed mode, solar would close, if not at temp and low speed mode,, solar would open and it would automatically kick to higher speed.
Seems like right now you can have heat on, or off, but can't schedule it to come on or off based on your desires (i.e. close solar for lower speed mode).
Last question: In the Hayward OmniPL Menu under Heat/Cool: Setpoint Temperature shows MAIN and SOLAR. I have gas heat for Spa only and Solar for the Pool, set in Heat Mode Only, Priority for both set to 0. Is the "setpoint" the temperature that I want the water heated to when the Gas (Spa) or Solar (Pool) are on, or are the two slides the temperature to turn on (left slide) and turn off (right slide)?
Thank you
Thank you
