Hi,
I have a pool and spa that are completely run on separate equipment, except they share the same Hayward heater. Recently we needed to replace two actuator valves. We were able to get them operating through the app correctly so that when you select heat on either pool or spa it heats the appropriate body of water.
My problem is in the app it says it's always in pool mode even when it is heating the spa. Then it seems to randomly switch the valves back to pool mode without any input. Any help would be appreciated thanks
