Took the cover off my pool yesterday to fire up the pump. Powered up the Omnilogic panel and the pump. Pump is wired/controlled by the Omnilogic. Pump not working. Panel showed an alarm – “VSP Comm Loss-HNA:2 NODEID: 2071”. Went through Config. HUA was listed. MSP and MP were older revisions. Updated them. Powered everything back up. Same alarm. Entered service mode. Saw that I could clear the alarm and did that. Still, pump not working. Rechecked HUA. Now it’s not listed. Power cycled everything. No luck, HUA still not detected. Isolated the pump from the panel to operate as a standalone including reconnecting the pump display board to the drive low voltage RS485 connector. Display did not power up. Checked for 12v at the RS485. Nothing. There is 240 volts at the pump. I checked everything else I could think of. Replaced the battery on the pump display board, all LED’s on the Omnilogic PC board working as they should. Checked all fuses. Everything worked at the end of last season when I powered it down for the winter. I’m at a loss. I’m thinking the pump is gone but want to hear if there could be anything else. Thoughts? Ideas? TIA.
