I have the below pool pump that has recently developed a really loud buzzing sound while running. I've checked to make sure there are no obstructions, water is coming out of the returns in the pool, and I've backwashed the sand filter. I see no visible leaks. I'm able to manually turn the impeller without issue.
One thing to note is that if I turn my plumbing dial to 100% skimmer then the noise significantly reduces.
