Hi there!
Our 24ft above ground hard sided pool is older but new to us when we bought this house last fall. Been learning the ropes and found out our CYA level is super high, about 150+. So we drained it down from 46" to 29". Then I got nervous about messing up the liner or worse and so have started to refill it. I'm concerned about the liner as it refills. I've attached some pictures - will this be ok? Or does this warrant intervention by us? Side note: luckily the water charges where I'm at are pretty low, so multiple drains/refills without going so low again are going to be affordable to us until we get the CYA diluted down to where it should be.
Thanks in advance!
Thanks in advance!
