- Jun 12, 2011
- 3,789
- Plaster
- Pureline Crystal Pure 60,000
I've been around here several years now, and now I'm baffled at my latest testing.
A little backstory: We had storm go through and I didn't get out and clean everything up right away. Temps have been record highs (110+). When I did clean up, there was a clump of debris on the sun shelf. When I moved it there was a decidedly green tint to the pebble tech underneath. I poured a couple cups of 10% bleach (that had been sitting in my garage for months stored at less than ideal temps) directly in the area, then added a full gallon, poured into the return stream.
I went ahead and vacuumed and cleaned before doing any testing. When I did test the OTO test was at or near the top level (5). The result was yellow, and comparable with the 5 color, not orange or brown with little chunks like I've seen before with very high FC levels.
Now comes the puzzle, FAS/DPD test time. 10 ml water, one rounded scoop of powder, then I start counting drops of reagent. I gave up at 100 drops. I don't see anyway my FC could be over 50, and if it were shouldn't the OTO have looked different?
I've done these test hundreds of times and this is a first for me. I even went and got different reagents from my son's test kit....same result. Waited a day, retested....same result.
Someone please tell me I'm not crazy, please.
