Calcium hardness is in the 70ish range and cya is 30 or less. I've already added the stabilizer, I'm just wondering if there would be any issue with adding calcium at the same time.
Side question, the stabilizer bag says I need to run the pump continuously for 48 hours, is this consensus of the experts here or can I scale back the pump time?
Thank you
Thank you
