I'll try to be as brief as I can. 9 days ago we had a party with a lot of swimmers. weather has been hot and sunny. the day after the swim readings were
FC-6
CC-0
PH-7.6
TA-70
CYA-70
CH-150
Borates-40
Salt-3600
Was gone for a few days, then 2 days ago the boss sprayed fertilizer on lawn near pool(she is always very careful around pool), but 6 hours later I mowed the yard( and I always end up with some grass clippings in pool. I mention this as a possibility, but I don't think this is the reason. Anyway, yesterday I go out to check chems and find a very cloudy pool, not green, just very cloudy. and the results were
FC-0
CC-0
PH-7.4
TA-100
CYA-40 possibly 30
I added 484 oz of bleach and 60 oz of stabilizer(all I had left) and tossed in 11 oz of acid to work on TA. Then ran to the store for more bleach.
3 hours later FC was 1, so I added 605 oz of bleach and tossed 3 tabs in the skimmer for CYA and backup. ( I must add that all this time I forgot that I cranked up salt gen to 100% and left it running, so this will skew my todays results).
At 6:00 last night FC was 17, so I called it a day, left pool running with tabs still in skimmer and SWG running at 100%(not on purpose, just forgot about it)
Today is looking better, pool is starting to look a lot clearer and FC was 11.5 and CC-1. added more bleach to Slam level and waiting.
All of this leads to my questions,
1-could this have been a fertilizer problem ( she fertilizes 2 or 3 times a year around pool area and we have never had a problem)
2-could the big loss of CYA be caused by this or if I let the FC level drop to zero would the sunlight and organics eat up the CYA.
3- could this be because I left town and my CYA and FC were getting low anyway and nature took over(kinda what I think happened since SWG was set at 50% and pump was only running 3 hrs in morning and 3 hrs in the afternoon, which is what I run it at normally with no problems.
I caught it in time so we should be okay, but I would like to figure out what happened to avoid this in the future. There you go Kim.
Si
FC-6
CC-0
PH-7.6
TA-70
CYA-70
CH-150
Borates-40
Salt-3600
FC-0
CC-0
PH-7.4
TA-100
CYA-40 possibly 30
Si
